ITX case that will hold ATX power supply?
So I'm putting together a new LAN rig, and the new Zotac LGA1156 ITX motherboard fits the bill perfectly.
However, ITX power supplies don't seem to get much above 300 watts, and a 5970 needs that much by itself. Anyone know of a case for an ITX motherboard with two expansion ports and compatibility with ATX, or at least, Micro ATX, power supplies?
3 answers Last reply
More about case hold power supply
  1. Nevermind (wish I could delete this), Lian Li has just such a case (other than the 2 expansion ports):
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811112227
    Shoulda known...
  2. Right, but is that case big enough to house the 5970?
  3. It won't without some modification: if you cut out the portion below the 1 expansion slot, it could.
    But like I said in the post right above yours: it only has one expansion port, and therefore, probably won't hold anything fast for a while. Not until a vendor modifies a 58xx series card for a single slot and either drops a video connection or changes over to multiple HDMI ports (which would work).
Homebuilt ATX Power Supplies Cases Motherboards Systems Product
