Solved
Help setting up OC
Windows 7 Home Premium x64
Intel Core 2 Duo CPU E6750 @2.66Ghz
Asus P5E-VM HDMI mobo
6 gb Ram (2gb Patriot DDR2-6400, 4gb Ballistix DDR2-6400)
GeForce 9500 GT (1gb DDR2)
80gb Maxtor HDD (I just ordered a 1tb Seagate Constellation to replace this)
Also, i have another question troubleshooting question that is on these forums that will help anyone trying to help me.
http://www.tomshardware.com/forum/51857-63-computer-loc...
More about : setting
Best solution
CPUs Master
Overclocking Master
Not sure what you mean by setting up an overclock. You either overclock or you don't , you can start to overclock but you don't set one up. The best way to start is to read yp on overclocking so that you have a good idea of how to do it. There are several stickies here in the forum telling you about overclocking and how to go about doing it and if you have a cpu that can be overclocked.
Ask the community
