Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > No PS3 surround sound using Gigabyte Optical input
Forum Motherboards & Memory : Gigabyte No PS3 surround sound using Gigabyte Optical input
I just installed the optical input card that gigabyte makes onto my ep45-ud3r rev1.1 so i could get surround sound from my ps3. But it doesn't work. I either get an extremely bad static sound or just 2 channel audio. I tried a couple games and didn't get anything but static. And i only got 2 channel audio when i tried to watch the District 9 Blu-Ray. Is there some hidden option somewhere that i need to enable to get 5.1 or do i need to buy a new audio card?
Thanks
>Ryan
Reply to rmccullough
Unless, you have the Optional/separate S/PDIF input I/O connected - the S/PDIF on the MOBO is output only, and only 2-channel input. I assume by PS3 you mean inputting audio from your Play Station 3 into your PC.
http://i1013.photobucket.com/albums/af254/Jaquith/spdif_optional.jpg
Verify that the S/PDIF is indeed connected to the SPDIF_I connection on the MOBO. Next, rather that rewriting the Manual - download and begin on page 107 of the PDF. There you'll find a detail "How to" and software setup.
GA-EP45-UD3R - http://download.gigabyte.us/FileLi [...] 3(r)_e.pdf
Good Luck!
Message edited by jaquith on 08-17-2010 at 07:15:34 PM
Reply to jaquith
I have it connected right. But i found out that the onboard audio can't decode dolby/dts audio from my ps3. So i just bought the Logitech z-5500 which do it all.
Good to know. Expensive but very cool fix.
BTW - you can change the audio output on the PS3 to a format that "may" work - http://manuals.playstation.net/doc [...] utput.html
Good Luck!
Reply to jaquith
It was semi-expensive($200 off ebay), but i've wanted those speakers for a few years. This just gave me an excuse to get them.
I tried every setting i could think of and i could only get the 2 channels to work.
Correct; hence the problem with the SPDIF standard. The only surround formats that can be carried are Dolby/DTS audio, which need to be decoded, otherwise you get static as the output. Annyoing, since the only way for a PC to decode said audio formats is through some other program (Windows Media Player. Cyberlink PowerDVD, etc).
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
There are 1818 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Do I need a new motherboard?
By smorizio, 4 hours ago:
you waste your money unless you where getting an overclock cpu. any new mb with the same...
Best offers
