CPU Overclock Fail! Need Help!
I recently tried overclocking my Intel Core 2 Quad q6600 from the stock 2.4GHZ to try and make it 3.0GHZusing the bios on my mobo. I read that people safely did this at 3.2GHZ with a stock cooler so I just decided to go with 2.7GHZ. I used CPU-Z to figure out my core multiplier and it said it was 6. I changed my fsb to 450 which would be 2.7. After I saved the setting my desktop will not power on now. I tried resetting the cmos (left it out for 30 minutes) and pulling out each piece of hardware and testing it individually. All hardware works and the motherboard light comes on as green (not sure if that helps any). I have no clue what else to due. Please help! By the way my motherboard is an Intel DG43RK using Kingston 2x4GB DDRE 1333 memory.
More about : cpu overclock fail
Related ressources
- Overclocking CPU Core Fail Error HELP DIAGNOSE - Forum
- Q6600 Overclock fail . - Forum
- Risks of Overclocking? " Overclock Fail !" - Forum
- Overclock fail 2550k more than 70 degrees - Forum
- http://www.tomshardware.com/forum/ [...] rts-stores - Forum
there were several mistakes you made.
first thinking that if someone else could achieve that type of overclock you could too without doing it in small increments and testing along the way.
two, you were completely wrong on the multi, you should have googled it and found out its 9 and not 6:
http://ark.intel.com/products/29765/Intel-Core2-Quad-Pr...(8M-Cache-2_40-GHz-1066-MHz-FSB)
three, that motherboard you have is a G43 chipset and is completely horrible to overclock with. you would have done better (but still not as high as you thought) with a P45 chipset.
four, you have no idea WTF you are doing. please stop and read some guides and understand what to do before doing it!
hope this helps. (and that you didn't fry anything!)
Anonymous said:
there were several mistakes you made. first thinking that if someone else could achieve that type of overclock you could too without doing it in small increments and testing along the way.
Lol you are right, i tried reading some stuff on overclocking and I thought I had it figured out but I guess not XD
Your FSB is defaulted at 266 if my calculations are correct...OH, RTC can be reset by pulling the jumper from 1-2 to 2-3 for about 5 minutes then put it back on 1-2...So if you get it to boot up..Start out by pulling the RAM multi back to x4 and then bump up the FSB to 300..That will be 2.7 GHz on the CPU and 1250 MHz on the RAM...Remember the FSB is the volume control of the system ...It OC's all components in the system
page 53 of the manual at:
http://downloadmirror.intel.com/18711/eng/DG43RK_Produc...
least i could do after my negative comments, sorry about that
Anonymous said:
page 53 of the manual at:http://downloadmirror.intel.com/18711/eng/DG43RK_Produc...
http://img545.imageshack.us/img545/3805/captureopi.png
Looniam, you are a life saver XD
Anonymous said:
you may get lucky(?): look at the capacitors on the mother board if any have a bulge on the top or any transistors looked like they "browned out", you found the problem. but ram or cpu would need to be tested in another rig to find out about.Replaced ram with ram that I pulled out my current rig and I have no way of testing the cpu. And all the capacitors look fine and the motherboard I just bought last month so hopefully that didnt die.
Lol well before i bought this motherboard my previous motherboard fried due to a faulty power supply and it was doing the exact same thing as this one. I'll call my friend after I get some sleep and see if I can borrow one of his. Ill post the result when I get a chance. Thanks for all the help guys.
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] rts-stores
- ForumNeed help OC'ing this system, my efforts fail ........
- ForumE4300 Overclock Fail - Why?
- ForumPhenom ll X6 1075T Overclock Fail
- ForumPlease help , new 7850 card makes display crappy catalyst fail or card?
- ForumCpu Only Blend test fail
- ForumNeed help to Overclock my Phenom x3 8650 with MSI K9A2 CF-F mobo
- ForumNeed to overclock my laptop CPU
- ForumHow to overclock cpu on dell xps 8500
- ForumCPU fail orthos, then seems ok?
- ForumCPU Fan Fail Warning on AMD PII X2 555
- ForumCPU fan clicking?
- More resources
Read discussions in other Overclocking categories
Yeah I do, looniam...
