Solved
How do I read a power supply?
I've been hearing that it isn't about how many watts I have, but what I have on the 12 rails. I don't know what that means.
I have a thermal take 600watt purepower.
It says I have
+5v 28a max load
+3.3v 30a max load
+12v 1 18a max load
+12v 2 18a max load
-12v .8a max load
+5 VSB 3a max load
Does the 1 and 2 next to the 12v mean the rails? What's a real anyways?
24 answers Last reply Best Answer
More about read power supply
  1. Best answer
    A rail is just a term that we use for the different voltages that come out of the power supply each voltage is considered on its own rail. Your power supply has 2 12v rails pushing 18 amps a peice so a combined total of 36 amps for a 600watt power supply that is a little on the weak side for the 12 volt rail. However depending on your system the Average single Graphics card system that is more then enough to power your system.
  2. jsc said:
    See where it says maximum 12 volt power is 648 watts (54 amps)?
    someone paid attention in math class ;)
  3. Something not mentioned is why the +12V rails are important. These rails provide power for your CPU and the expansion slots (including a graphics card). These components draw the most power. I believe the ram runs on the +5V and I'm not sure about the others. Someone correct me if I am wrong.
  4. Hey thanks guys. I sort of understand now. I just need to pay attention to the 12v. I did get my thermaltake on discount. It was only like $60.00 or so.
    I'm concerned about my popwersupply when I upgrade though. I currently have a
    E5200 2.5gig dual core with 4 gigs ddr2 ram, a dvd drive, GTX 260 graphics card and 2 hard drives.
    I'm upgrading to maybe an AMD AM3 motherboard with a Phenom or Athlon x4 chip. Will my current 600watt 36amp power supply need to be replaced?
  5. Yes it should be fine powering that system. You will only really need to upgrade if you go for a more powerful video card but you will be fine with your current setup and the future AM3 setup.
    Good Luck
  6. Quote:
    Again, it doesn't work that way. It can work that way, but thats not how you determine the COMBINED 12V amperage. You need to find the statement like JSC did and then do the math. My delta sourced EA500W is my favorite example. Each rail is rated at 22A, but I don't have 44A of power on the 12V rail. I only have 34.
    V * A = W
    :sol:
  8. ct1615 said:
    V * A = W
    :sol:
    P=VI
    Don't confuse units with the symbol.
    264W on each rail (I=22A and V= 12V) does not mean it will allow a total draw of 528W
    Here's a chart from OCZ:
    http://www.ocztechnology.com/images/awards/mxsp_wattage_charts.jpg
    Note that their 700W PSU has the same number of rails and the same amps per rail as their 600W, yet provides more power across both rails.
  9. enzo matrix said:
    P=VI
    not using symbols, simply didn't feel like spelling out amps, volts, watts
    glad you can paste and copy a wiki article *golf clap*
  10. Your missing the point. 18A on 12v1 + 18A on 12v2 != 36A. It might in some cases, but that's not the way you figure out how many amps the PSU can provide. You don't have to spell out the words, you can use the correct abbreviations.
    who are you talking to?
  12. Saaiello mostly. First reply.
    Excuse me? I did not visit wikipedia at all. This comes from my experience in computer engineering.
  14. So how exactly do yu determine the total power on the 12v rail?
    I've been trying to figure that out since I found out that it's not VI+VI. So far, all I can figure out is that you have to check with the manufacturer. If you look at the link I posted, both the 600W and 700W versions have the same amps on the +12V rails and the same number of rails but one supports 500W and the other 550W.
  16. The only way to know before you buy is to look at the label. The manufacturer has to list total power available on the 12V rail(s) combined. Usually written as "12v1 and 12v2 not to exceed 408W" or some other total output number. Do the math, you'll get your amperage. If they don't list it, you can perhaps find a review where they test it. Other then that, you really have no idea.
    OK. :) RAM runs of the 3.3 volt rail. It uses a simplified version of the programmable power regulator that the CPU does. Measurements on my first Core2 system indicated that 2 GB of DDR2 RAM running at 2.1 volts pulled 6 amps or 20 watts of power.
    I buy single rail Corsairs now. :D
    But you could read the PSU label (see my two links above) and if the label doesn't tell you the total (like the first), don't buy the PSU.
    I also have an Antec 650 watt TP3. It has 3 rails (allegedly), each max rated at 19 amps. The label also says that max 12 volt output is 624 watts (52 amps).
  18. Why is it that some PSUs have lots of amperage (up to 30A) in the +3.3v rail and very little the +12v rail? Apart from RAM, what else does this rail (the +3.3v rail) provide power to? [:fixitbil:1]
    Obsolete design , dressed up with modern cables.
    SATA drives. 3.3 volts comes off the orange wires.
    So they can say it's a 600W power supply when the +12V rails can only provide as much as a modern 300W.
  21. you can find 12V ratings for many units here:
    http://forums.guru3d.com/showthread.php?s=80ed7896f1bd130a429f0267ba1d01eb&t=205763
    The OP's model 12V rating is listed in the specs at Thermaltake as 38A...the label is wrong and missing the third 12V/16A rail this design has. It's a 550W unit btw...TT overrates this one 50W...but it's a good CWT-PSH design.
  22. Best answer selected by tuesday0180.
Power Supplies Components Product
