Hello all. Its my first time on the site and im looking for advice with my first build. I have a general list of parts but the problem that i keep running into is what processor i should use. Now without further ado, the parts:
Intel Core i7 920
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202&cm_re=core_i7_920-_-19-115-202-_-Product
P6T X58 1366 ATX Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365&cm_re=P6T_X58_1366_ATX_Motherboard-_-13-131-365-_-Product
(I'm pretty sure this is the one...)
GeForce GTX 260 OC MAXCORE 55 896MB GDDR3 PCIe 2.0 Graphics Card
http://www.amazon.com/BFG-GeForce-MAXCORE-Express-Graphics/dp/B0029D8D32
XMS3 6GB DDR3-1600 (PC-12800) CL8 Memory Kit (Three 2GB Memory Modules)
http://www.newegg.com/product/product.aspx?item=n82e16820145222
TX750W 750 Watt ATX 12V Power Supply
http://www.microcenter.com/single_product_results.phtml?product_id=0273362
Deskstar 1TB 7200RPM SATA Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145287&Tpk=Deskstar%201TB%207200RPM%20SATA%20Hard%20Drive
22x DVD RW Burner with Dual/Double Layer Support OEM
http://www.microcenter.com/single_product_results.phtml?product_id=0293049
Cooler Master Sileo 500
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119192
(Won at a Lan Party which started this whole build)
Ok that is about all that im thinking about purchasing. I know little to nothing really about building a computer and am depending on my friend to help me put everything togeter. The main problem is the choice between the Core i7 (being discotinued soon) and the less powerful Core i5. The computer will be used to replace the family computer (web browsing, light gaming, photoshop and illustrator).
Any help or tips?
Intel Core i7 920
Any help or tips?
