Here is the system i plan on build in a month or so and the list of water cooling upgrades i plan tp buy later on. So how des everything look? Any suggestions? Also, will I be ok to use a molex splitter? I will not have enough molex plugs on my PSU so I will be getting a splitter that turns 1 into 4 so that's an additional 3 plugs giving me 9 in total and i will probably use 8 at the most? I will have some LED's, fans and fan controllers as well as the pump all on molex so will I have enough power for all thatalong with all the other things like SATA and powering my mobo and GPU?
OS: Windows 7 Home Premium 64-Bit OEM
Case: AZZA Genesis 9000B
MoBo: ASUS Maximus V Gene LGA 1155 Intel Z77
RAM: Corsair Vengeance LP Black 8GB (2 x 4GB) 1600
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz Quad-Core
HSF: COOLER MASTER Hyper 212 EVO
GPU: EVGA NVIDIA GeForce GTX 670 FTW 2GB
SSD: SAMSUNG 830 Series 128GB
HDD: SAMSUNG Spinpoint F3 1TB 7200RPM
PSU: OCZ Fatal1ty 750W
ODD: ASUS DVD Burner OEM
Fan Cont: 2x Scythe Kaze Master
Fans: 12x Scythe Gentle Typhoon 120x25 - 1850 RPM
Top Rad: Coolgate Quad 120mm Ultimate Heat Exchanger
Bot Rad: Coolgate Dual 120mm Ultimate heat Exchanger
Pump: Swiftech MCP35X 12v PWM Controlled Water Pump - Black
Res: XSPC Laing DDC Reservoir Pump Attachment
CPU Block: Bitspower Summit EF CPU Liquid Cooling Block - Ice Red Acrylic
GPU Block: Koolance VID-NX680 GeForce VGA Liquid Cooling Block
SLI Bridge: Enzotech SLI Bridge Fitting Set - Matte Black
Tubing: Danger Den DreamFlex Value Pack - UV Red (1/2" ID x 3/4" OD)
Clamps: 10x Lamptron Elite Aluminum Reusable 3/4" OD - Anodized Deep Red
Fittings: 8x Enzotech G1/4" Barb Fitting - 1/2" ID Matte Black
2x Enzotech G1/4" Thread 90-Degree Rotary Barb Fitting - 1/2" ID Matte Black
