Motherboard power connector confusion, please help!
My motherboard is GIGABYTE GA-MA770T-UD3P:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128392&Tpk=ma770t-ud3p
Power supply is OCZ StealthXStream 700W:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341019&cm_re=stealthxstream-_-17-341-019-_-Product
The motherboard has a 2x4 ATX 12v connector AND a 2x12 ATX connector.
The PSU has a 20+4 wire which I understand is to go to the 2x12.
My question is what does the 2x4 connector do? Is it to power the CPU? The PSU has two 2x2 wires, named "CPU1" and "CPU2", so I should connect both of these to the 2x4 then?
5 answers Last reply
More about motherboard power connector confusion help
  1. You are correct.
  2. Yes, the 2x4 connector supplies power to the CPU. Connect both "CPU1" & "CPU2" plugs to that connector. They're keyed to only go one way, so make sure not to force anything.
  3. Great, thanks. I felt it is better to ask than connecting the wrong wires to the mobo.
  4. Because they're keyed, you can't make a mistake.
    That's completely understandable. It's better safe than sorry, right?
    Good luck with the build.
    The READ before posting about boot problems! sticky at the top of the forum has quite a few more troubleshooting ideas. It's a good idea for any new builder to read through the checklist so they can avoid some of the most common mistakes.
Homebuilt Power Supplies Motherboards Power Systems
