New Builder i5 build with some reused parts for now
Hi folks,
I really appreciate the knowledgeable help you all provide here, thanks for your input.
APPROXIMATE PURCHASE DATE: Next month or so, but I can wait for sales.
BUDGET RANGE: Around $700, but will spend more for the right components.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, but top performance not necessary.
PARTS NOT REQUIRED: Planning to reuse:
Samsung 24 inch monitor Native 1920x1080 5ms
ATI Radeon HD 4670 (will upgrade later)
WD Caviar Blue WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s (Will upgrade later)
PREFERRED WEBSITE(S) FOR PARTS: Newegg
COUNTRY OF ORIGIN: US
PARTS PREFERENCES: Intel i5 750
OVERCLOCKING: Just a little, conservative about this.
SLI OR CROSSFIRE: Would like the option to, but probably won't.
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS:
Would prefer a understated case, no flashy bling please. I like the stealthy look.
I'm reusing my current HD and graphics card for now which I know will limit performance until I upgrade them, but otherwise I'd like to get quality, proven components that together would provide a solid platform for later upgrades and the "future."
Not looking to include cheap components that I'll regret later, but I love a deal on quality stuff.
This will be my first build, so I'd like to avoid hard to install or tricky components.
Here are my current ideas for components:
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066 $59.99 ($69.99 -$10 instant savings)
OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016 $39.99 ($89.99 - $25 is - $25 rebate)
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3P1333LV4GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227478 $79.99 ($129.99 - $30 is, - $20 rebate)
IGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412 $134.99 ($139.99 - $5 is)
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor
$199.99
SAMSUNG Black 22X DVD+R 8X DVD+RW 22X DVD-R 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD Burner LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188 $31.99
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 $29.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754 $104.99
This gets me to $680 after rebates. I'll spend some more if anyone can make a compelling case to do so. Ideas for saving money are of course very welcome.
Thanks,
3 answers Last reply
More about builder build reused parts
  1. The only advice I can share is that, if you're planning to overclock, stay on top of potential P55 OCing issues: http://www.tomshardware.com/reviews/p55-motherboard-overclock,2460.html
  2. That's what I would get if I had $680 :-)
  3. The one thing that concerns me is the power supply is a little on the low side if you want to overclock and later add a high end graphics card like a 5850 or one of the soon to be released Nvida Fermi.
New Build Systems Product
