Hey guys...
I'm currently working on my case airflow. Have been experimenting a bit. My current cools the CPU quite well, while the Crossfire GFX cards are running a bit hot (had better GPU temps with former setup, though CPU temp would fire up during GPU load, receiving hot air)
My cards are non-ref, and I heard they tend to blow the used(hot) air into the case, just everywhere.
Illustration:
http://b.imgdrp.com/qxrG.png
What do you think about it - of course mostly interested in feedback on the planned setup
Should note, if you don't derive it yourselves, that I have 4 fans at my disposal.
I also only push in filtered air to try to prevent dust accumulation.
In my ideal world, both the GPUs and CPU is offered cool/fresh air, while of couse I don't want to scew case ambient temp.
Thanks in advance
EDIT: I don't think the airflow from the front is really strong enough, to remove the hot GPU air all by it self .
Illustration:
Thanks in advance
