I'm new to the forums btw. Here's my system:
ASUS M3A78-CM mobo (got this, and the memory and processor, to replace a burned out mobo I got about five years ago)
Phenom X3 2.1GHz (I can't remember the model, but that's the original Phenom, not Phenom II)
memory:2GB RAM (1 stick)
on-board audio and video (the plan from the beginning was to get a new video card when I got some more funds)
Samsung 955DF 19" CRT
500GB HD (SATA, Western Digital or Samsung I think...)
18x DVD writer (SATA)
Antec case (an old one but it's plenty big, model 1040 or something(I think the model number 1040 may refer to the fact that it has 10 bays, including 4 large ones- for CD drives, etc.)- incidentally, I should have gotten a different mobo probably- mine is not full size ATX I don't think, despite what the salesman said)
cheap 300W PSU (got this at the same time as the mobo, processor and memory, just to replace a burned out Antec PSU that came with the case)
Windows XP and sometimes Vista (dual boot configuration)
OK. So what happened is that I wasn't following the hardware industry for a few years before upgrading to this set-up about a year ago. Now that I've been reading about hardware again since then, I definitely would have done it differently. Now I plan on changing just about everything, although slowly, as funds become available.
First off, I need a new hard drive. I'm battleing to keep some space open on my half TB drive so I plan my first purchase to be a 1TB drive, especiallly because I've all but given up on trying to back everything up on DVD's, so I need some space to keep valuable information from not being backed up in the near future.
Secondly, I plan to add in a new video card and PSU. I'm very limited in funds but I love the sound of getting one of those new ATI cards, maybe a HD5770
LIKE THIS with a power supply to match- hopefully I can get away with spending about $40-50 on a new PSU if I find a good deal. Something like
THIS.
I guess next would be a nice but inexpensive LCD to go with that new video card. The right 23-24 inch LCD will support 1080p, correct?
THIS looks like a deal too good to pass up. Am I missing any obvious problems here?
Then the memory. Then the processor. Then the mobo. In that order I think.
Why did I not get a pair of memory sticks? I don't know. Was that a sizable mistake. Too bad, because memory seems to be more expensive now, unless it's just because it's all DDR3 now. Is that why?
The processor: I knew Intel was winning the race a year ago, but not as much as you might think. The Phenom X3 was under $100 so I don't feel like I made a bad choice being loyal to AMD, although the Phenom II's look much better. What are my upgrade options here? I hope I can wait a while to upgrade this and probably the mobo because it's going to be a while before I have funds to get all of the above, not to mention a new set of speakers and a new printer. I didn't even mention those above because I'm just using what I've cobbled together for speakers and the printer isn't even hooked up. Unfortunately I have to dual boot with Vista and XP because no one bothered making new drivers for my printer and scanner. I am using the scanner, a Canon FB630U, through windowsXP.
Unfortunately I have to reinstall my OS's or figure something out because windows' dual boot utility messed up my system to where I can only use XP now. Long story.
Anyway, any advice would be appreciated. Thanks.
