Need advice on settings for RAM OC
Hi guys.
I recently bought 4x4GB Ram : http://www.overclockers.co.uk/showproduct.php?prodid=MY-164-CR
which was compatible with my mobo : http://www.asus.com/Motherboards/Intel_Socket_1366/P6T_Deluxe_V2/
The ram is currently, by default, running at 1033mhz : http://puu.sh/13fKq
and i want to make it run at 1600mhz as it is capable.
I've tried using the XMP setting and i've been experiencing crashes :
http://puu.sh/13fMS
http://puu.sh/13fNk
I'm not computer literate so i don't want to make adjustments without advise. What settings should i use to run at 1600mhz and avoid crashes?
Please let me know if you need additional information. I'm not sure what other hardware you might need to know about.
4 answers Last reply
More about need advice settings
  1. Anyone?
  2. Still needing advice.
  3. You need a voltage bump it looks like ..What are the RAM timings in XMP ... example: 9-9-9-24-33-1T
  4. Enable XMP.
Memory RAM Compatibility Overclocking
