Iomega NAS network recognition problem
bennettwrite
I'm having issues with my 1 TB Iomega Home Media Network Hard Drive.
Disk spins and seems to work, but light on side flashes blue and orange (which is supposed to mean that the drive couldn't find an IP addy).
I've tried connecting the ethernet cable directly to computer (per troubleshooting diections) and no luck.
I've tried power-cycling, no luck.
Device worked fine up until I moved. I don't think it was banged around. I did switch routers...But new router has UPnP enabled and firewall turned off...(Belkin G Router F5D7230-4, firmware is current).
I'm fairly computer savvy, but this has got me...
Any help?
venunk
Hi bennettwrite,
I am also facing the exact same problem. Did you find a solution?
jefft104
5
