Tom's Hardware > Forum > Home Theatre > ReplayTV > HELP my R5540 isn'tconnecting to the network after power o..
Forum Home Theatre : ReplayTV - HELP my R5540 isn'tconnecting to the network after power o..
Archived from groups: alt.video.ptv.replaytv (More info?)
I cam home to find all my power had gone off and had to reset
everything.
I am able to use the ReplayTV to vie previously recorded programs and
my SETUP setting all look okay but I can only view programs/schedules
as far as Dec 31. In SETUP I tried to manually connect to the service
but got a message that there was network difficulties and it would try
again later.
What should I do? I have to leave home tomorrow and will be away for a
few days but don't want to miss Alias or Lost.
HELP!!!!
Thanks
Arawak
Sponsored Links
Try this in exactly this order:
1. UNPLUG the Ethernet cable - this is a very important step!
2. Unplug the RTV power cord
3. Wait 30 seconds
4. Plug the Ethernet cable back in
5. Plug the power cord back in
6. Wait for the "Please Wait" screen to finish
7. THEN go to setup and do a manual connect.
Assuming that your router is working properly (lightning took mine out
once) you should be good to go.
fake_address@hotmail.com
> everything.
> again later.
> HELP!!!!
> Thanks
> Arawak
Reply to Anonymous
Your suggestion worked beautifully.
Thanks you ever so much,
Cheers,
Arawak
On Wed, 29 Dec 2004 09:39:57 GMT, "BruceR" <brNOSPAM@hawaii.com>
>3. Wait 30 seconds
>From:Arawak
>> everything.
>> again later.
>> HELP!!!!
>> Thanks
>> Arawak
Reply to Anonymous
Glad it worked for you!
> Cheers,
> Arawak
>> 3. Wait 30 seconds
>> out once) you should be good to go.
>> From:Arawak
>>> everything.
>>> and my SETUP setting all look okay but I can only view
>>> programs/schedules as far as Dec 31. In SETUP I tried to manually
>>> connect to the service but got a message that there was network
>>> difficulties and it would try again later.
>>> for a few days but don't want to miss Alias or Lost.
>>> HELP!!!!
>>> Thanks
>>> Arawak
Reply to Anonymous
There are 1018 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
