First of all let me tell you I virtually have NO clue when it comes to overclocking:
My New PC is this:
Asus M5A97 Mobo
AMD FX-6100 CPU
Corsair TX-650 PSU
XFX Double D 2GB HD7850 Graphics Card
Kingston 128 GB SSD
Seagate 2TB HDD
8GB Gskill DDR3 1600 Ram
V7 24\" HD Monitor
Lite on Cd/DVD
Asus CD/DVD Writer
Cooler Master Hyper 212 Evo
Win 7 Pro 64bit
So I built this PC a little over 1 week ago and it runs great, in stock configuration, but when I set it to turbo in the bios with the low fan setting set to 200RPM and cool & quiet turned off the thing crashes with event 41, kernel-power error. Same thing if I use the asus AI suite 1.02.03.
When i say it crashes, it crashes when I try and play Guild Wars 2, it also crashes when I run the OCCT:LINPACK and OCCT:GPU tests, the OCCT:CPU and the OCCTower tests run fine. all of the OCCT tests run fine when it's in stock configuration as well.
I updated my graphics drivers and flashed the bios to the newest bios version and re-ran the tests and the OCCT:LINPACK test ran OK, but the OCCT:GPU test crashed. Could have been because I ran them back to back, or it could have been that I didn't allow the OCCT:LINPACK test to run long enough after updating the drivers?
So here I am wondering if I actually have a problem, or if it's the software(asus suite or the bios turbo) causing the problems for me?
As I said earlier, I have NO idea how to OC this thing manually and don't want to go in there fooling around with settings and screwing something up.
Any help or advice would be greatly appreciated. I'd really like a pointer to a walktrhough (If something like that exists) on how to overclock the setup I have.
Thanks in advance
My New PC is this:
Asus M5A97 Mobo
AMD FX-6100 CPU
Corsair TX-650 PSU
Kingston 128 GB SSD
Seagate 2TB HDD
V7 24\" HD Monitor
Lite on Cd/DVD
Asus CD/DVD Writer
Win 7 Pro 64bit
Thanks in advance
