Solved
Can Thermaltake SpinQ VT fit in Thermaltake V9 case?
Can this cpu cooler: (depth = 159 mm)
http://thermaltakeusa.com/Product.aspx?C=1405&ID=1904
fit into this case? (depth = 191 mm)
http://thermaltakeusa.com/Product.aspx?C=1390&ID=1819
I'm building a new system to replace my 7 years old PC. I've all the specs in my mind.
Only 2 things left is the case and the cpu cooler. I'm going to order the above two. Anyone know if SpinQ VT fits in V9 case?
Thank you in advance. =)
P.S. If not, please feel free to recommend a cpu cooler + case combination. My criteria is:
- The case should have power supply dust filter. (the V9 has it)
- The cpu cooler should be quiet. The mediocre performance is fine.
- Budget: $200 for case & cpu cooler combined.
9 answers Last reply Best Answer
More about thermaltake spinq thermaltake case
  1. Best answer
    The cpu heatsink will not fit in the case.
    The Thermaltake V9 case is 7.52 inches wide.
    The Thermaltake SpinQ VT is a tower style cpue hatsink that 159mm tall.
    Those tall tower style cpu heatsinks require a pc case that is at least 8 inches (204mm) wide and a case that is at least 8.5 inches wide if there is a case fan mounted on the side panel..
    Have a look at the Lian Li / Lancool Dragon Lord cases. Th cases meets your requirements. They come in a variety of configurations and prices. Ventilation, airflow, cooling, fan noise, space, and cable management are excellent.
    http://www.lancoolpc.com/en/produc [...] s_index=62
    Here is a link to a video review of the pc-k60 version made by one of the veteran posters at this forum:
    http://www.youtube.com/watch?v=U2MdUGxWEcU
    mwave.com has the lowest prices in the USA:
    http://www.mwave.com/mwave/deepsea [...] &ALL=y&TP=
    Here is a link to a very good web site with more useful information about cpu heatsinks that will help you make an informed decision:
    http://www.frostytech.com/top5heatsinks.cfm
    You can use the Google embedded search feature at the web site to find more information about heatsinks for specific cpu sockets.
    Personally, I'd recommend the Coolermaster Hyper 212+ cpu heatsink. It is much better than mediocre and represents a good value. If you shop carefully you can sometimes find it onsale for $29.99 in the USA.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=hyper_212%2b-_-35-103-065-_-Product
    Here are links to technical reviews:
    http://www.google.com/search?hl=en&source=hp&q=cooler+master+hyper+212+plus+review&aq=2&aqi=g10&aql=&oq=cooler+master+hyper+&gs_rfai=
  2. Hi newcomer and welcome to the Tom's hardware forum.
    ^+1 to JohnyLucky], the max that you can install is the CM Hyper 212+, or one with the same specifications.
  3. Saint19 - Are you sure? The Coolermaster Hyper 212+ is 158.5 mm tall. It won't fit in the Thermaltake V9 case case either. On the other hand the Dragon Lord cases can accomodate it with room to spare.
  4. ^100% sure, take a look of THIS link and you can see a thermaltake V9 with a CM Hyper 212+ inside.
  5. link not working. tight fit?
  6. ^Yeah sorry for that. Check the link on the post.
  7. Excellent photos.
    Didn't think it would fit. Normal recommendation is for a case 8 inches wide.
  8. ^Thx, fit perfectly the problem is that is a old mobo and I want a 790FXTA for a better OC and general performance with DDR3 and a new ATI 58xx series.
  9. Best answer selected by lgmcben.
Power Supplies CPUs Cases Cooling Thermaltake Components Product
