Dear Tommies,
Today I replaced my 6600GT with a HD5850, quite an upgrade.
I also moved all my components to a way bigger case.
I'm very sure everything is connected properly but the system just won't do anything.
As for the minimum to start a system:
PSU cable in a power socket: Check
PSU 24-pins ATX on the mobo: Check
2x4-pin ATX on the CPU: Double-molex to 6-pin (this should suffice since the board should also start with 1 4-pin. 2x 4-pin is only for >130w CPUs)
My setup:
600W Modular Zalman
GA-EP45-UD3P
E8500 C0 (Intel Stock)
4x1GB Team Xtreem PC2-6400 CL4
MSI ATi Radeon HD5850 OC
Again, the only new components are the GPU and case. Even without the GPU inserted there's no sign of power at all. The PSU should be able to keep up with the card anyway.
The power switch on the PSU is on too.
I'm really feeling dumb at the moment since I'm fine with computers but have been working on this b!tch all day.
Any input is more than welcome!
My setup:
600W Modular Zalman
GA-EP45-UD3P
