I believe that the Hyper 212 EVO cooler has an adjustment on it for the fan to be raised up in order to clear the ram heat spreaders. You can also mount the fan on the other side so it doesn't come in contact with the ram sticks at all.
Your link isn't working. But if you don't have the tall heat spreaders then you should be ok with any of those coolers it's when you have the tall heat spreaders like the ones here in this link that you could have an issue.
The ram heatspreaders have to be the tall stylein order to be a problem for the heatsink and when installing the newer style heatsinks the low profile ram sticks are prefered because they don't interfere with the heatsink.
Thermaltake cpu heatsinks are not quite top quality and the Cooler Master Hyper 212 Evo or Plus models are much better. The models you have mentioned are Cooler Master and not Thermaltake.
You have the V6 maodel and the V8 model below that you could consider.
Well mainly, im really considering if those bigger cpu coolers will not hit my RAM slots. I can only order stuff to be delivered to me, there are no nearby retailers of such items here so I have to be sure of dimensions and whatnot.
My stock CPU fan for 965 BE is almost touching my RAM as of now.
