Need temporary replacement card
:fou: i need a temp card my 9800gt is dead, i am going to buy an new computer and card in 2 months i am just going to be playing left 4 dead 2 ccs
i was think of these
8600gt 512
hd 4350 512
hd 4550 512
7900gt 512
2600 xt 256mb
i was jsut going to buy an used one off ebay of so
11 answers Last reply
More about need temporary replacement card
  1. get 4670, that should be enough.... :)
    or 8600gt.
  2. ... Yeah I don't like any of those choices.
    The 7900gt 512MB would generally be a little faster than the 8600, but there may be some driver issues using it on a newer motherboard, (discontinued support and all). Of course, it's only a DX9 card. Of the DX10 cards the 8600gt 512 would be the fastest. The 2600XT would be limited by the small 256MB and the 4550/4350 would be crap for any recent games.
    If you're buying something used off of eBay then just go with a Radeon 3850 512MB as they should be rather cheap and are much faster than the cards you listed.
  3. If you are going to be building a new system in two months don't bother wasting money on a temporary card. Just buy the video card for it a few months early.
    What resolution is your monitor? Or what it will be on your new one if you are upgrading it to go with the new system.
  4. ^^^^^^^^^^^^^
    +1
  5. i'm guessing your waiting for Fermi?
  6. i am waiting for Fermi what about eForce 8800GS Superclocked 384MB i found one for 30us on ebay people are selling the hd 3850 for 100 or more i mean really, also an 2900xt for 499us is the 2900xt some type of super card thats way to much, i game at 1280-960 :fou:
  7. That's a good choice. It should OCs very well up to around 700mhz which should make it similar to a 8800/9800GT
  8. I meant the 8800GS BTW.
  9. since it only has 384mb :o would i be able to max out left 4 dead 2
  10. OCed and at low resolutions (1280x1024 and below) it should be able to handle that or come quite close. L4D2 isn't very intensive on GPUs.
  11. ^+1
    Surprised that 3850s would be running that high on eBay. I haven't checked lately myself. I got my second 3850 for like $50 new early last year, so $100 for a used one just seems insane.
    Anyway the 8800GS should be fine for now. As jyjjy said, you shouldn't be too concerned about the 384mb of RAM.
Graphics Cards Computer HD Graphics
