Ok i got some help already and replaced alot of te things i was going to get and want to make sure this will work. I dont want to spend more then $750, all i will use his for is world of warcraft, and videos. I have never built a computer before so all your input would be good. Thx
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
ASUS M4A78LT-M LE AM3 AMD 780L Micro ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131619
SAPPHIRE 100258-1GHDMI Radeon HD 4850 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102837
AMD Phenom II X2 550 Black Edition Callisto 3.1GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103680
G.SKILL 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL8D-2GBHK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231134
CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Open Box: ViewSonic X Series VX1962wm Black 19" 5ms, 2ms (GTG) Widescreen LCD Monitor 300 cd/m2 DC 6000:1(1000:1) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116391R
