Better to use serial>molex or split a molex into 2?
I'm using a power supply that only has 1 Molex plug. I have a hard drive and an optical drive that require molex power.
Is it safer to use a molex Y splitter to change that 1 molex into 2 molex plugs
or
use that 1 molex plug for he hard drive then use the other serial plugs and attach a Sata>Molex adapter for the optical drive?
2 answers Last reply
More about better serial molex split molex
  1. It is safe to use the splitter.
  2. doesn't matter, the wiring inside chain of molex connections is logically the same as a Y splitter, else there would be significant voltage drops (50%) with each connector.
Power Supplies Optical Media Hard Drives Components
