Help for Overclock RAM
H!
my system spec :
CPU : AMD phenom II x2 565BE unlock to x4 B65
RAM : G.skill ripjaws x 1600MHz 2x2GB cl8
main : asrock 870 extreme3 r2.0
vga : msi gtx470 twin frozr
power : memonex 600w
i can't overclock ram above 1700mhz cl8 !
voltage ram = 1.65 (defult = 1.5)
voltage CPU = 1.45 !
voltage HT = 1.35
HT = 1.3
NB = 1.3
and ... !
what is my problem ?
ram isn't Compatible with this platform ?!
Main is poor ?!
or i can't overclock
tnx
3 answers Last reply
More about help overclock
  1. i as well can't get past 1600MHz without instability (i ran 11.11.11.42 timings and still crashed @1700MHz)
    i suggest keeping lower frequency's and tighter timings, that has worked better for me
  2. There isn't much benifit from overclocking the ram so it's not worth the trouble to fight with it to get it stable at higher speeds. You would see a couple of FPS more at most.
  3. inzone said:
    There isn't much bebifit from overclocking the ram so it's not worth the trouble to fight with it to get it stable at higher speeds. You would see a couple of FPS more at most.
    I agree. There isn't much performance gain to be had from overclocking RAM, and if you are already running 1600MHz at 1.65V that should be the top end of your RAM anyway. 1.65 is a high voltage already and if you're not able to boot at any combination at 1.65v then you probably shouldn't go any further.
    As stated previously, 1600MHz is more than enough, those higher clocks won't show you any real performance gain.
Memory Overclocking RAM CPUs
