I wouldn't bother replacing the standard fans, they should be cool and quiet.
Best thing to do is set it up and run some stress tests while monitoring the temps, you may find everything is cool and there is no need for increased cooling.
HWmonitor
Prime 95
OCCT
3D Mark
If not depending on whats heating up will determine where you need to add cooling power.
