Problems with my Razer Barracuda Hp1
I just got a complete new computer and ofcourse i tranfered my Razer brracude HP1 to this new computer, the problems is though, that there is a tiny buzzing or humming sound in my headset (was not there before)
And the inbound volume on my microphone (when i try to speak to others over ventrilo or skype) is extremely low, and my settings are as high as they get.
Can it be because it's an onboard sound card that does not support this headset?
Motherboard is the : p7h55-m Asus
Please help
2 answers Last reply
More about problems razer barracuda
  1. Check the settings within windows and your audio drivers and you may find an option to allow a microphone "gain" or "Boost". Which will allow the microphone to listen more carefully w/o being set to max.
    If you use Windows XP,
    1. Click Start
    2. Click Settings
    3. Click Control Panel
    4. Open "Sounds and Audio Devices"
    5. Click the Advanced button in the Device Volume section.
    6. Click options
    7. Click Properties
    8. Click the "Recording" radio button
    9. Click "OK"
    10. Click the advanced button under the microphone input volume.
    11. Make sure there is a checkmark in the "Microphone Boost" box
    If this setting is already set correctly. Then it could be a setting within the audio drivers software. If you are certain all settings are correct then you are likely getting "radio interference". It isn't always caused by radio signals but electronics can cause it too and almost any piece of hardware in/on the motherboard could be the cause.
    You can either send the motherboard to ASUS for RMA.
    OR
    Buy a sound card. (Sound cards tend to be less susceptable to this type of issue.)
    Here is more information about interference by the FCC:
    http://www.fcc.gov/cib/consumerfacts/interference.html
  2. Awesome, thanks a lot i will try that!
    Thanks a lot man! Cheers
Asus Computer Razer Motherboards
