Connect desktop to wireless router via ethernet cable
Last response: in Wireless Networking
I just installed my Jensen Airlink 29150 150 Mbps wireless router.
It's setup this way; Internet cable goes into my modem, a ethernet cable goes from the modem into the WAN port on the wireless router and finally a ethernet cable is connected from one of the LAN ports on the router to the LAN port on my desktop.
I've installed the wireless router to get online with my Wii console and I don't have a wireless usb adapter for my desktop, which is why I want to connect it via the ethernet cable.
When I try to connect to http://192.168.1.1 (or 192.168.1.x - tried everything from 1 to 9), nothing happens.
This is what I get when I run cmd->ipconfig/all:
C:\Documents and Settings\HP_Administrator>ipconfigall
Windows IP-konfiguration
Værtsnavn. . . . . . . . . . . . . . . . . . : KÅMPJUDAR
Primært DNS-suffiks. . . . . . . . . . . . . :
Nodetype . . . . . . . . . . . . . . . . . . : Hybrid
IP-routing aktiveret . . . . . . . . . . . . : Nej
WINS-proxy aktiveret . . . . . . . . . . . . : Nej
Søgeliste for DNS-suffiks. . . . . . . . . . : intern.ka-net.dk
Ethernet-netværkskort LAN-forbindelse:
Forbindelsesspecifikt DNS-suffiks. . . . . . : intern.ka-net.dk
Beskrivelse. . . . . . . . . . . . . . . . . : NVIDIA nForce Networking Co
ntroller
Fysisk adresse . . . . . . . . . . . . . . . : 00-18-F3-4C-52-29
Dhcp aktiveret . . . . . . . . . . . . . . . : Ja
Automatisk konfiguration aktiveret . . . . . : Ja
IP-adresse . . . . . . . . . . . . . . . . . : 85.202.31.231
Undernetmaske. . . . . . . . . . . . . . . . : 255.255.240.0
Standardgateway. . . . . . . . . . . . . . . : 85.202.16.1
DHCP-server. . . . . . . . . . . . . . . . . : 192.168.127.115
DNS-servere. . . . . . . . . . . . . . . . . : 192.168.1.3
192.168.1.9
Rettigheden opnået . . . . . . . . . . . . . : 26. marts 2010 17:31:18
Rettigheden udløber. . . . . . . . . . . . . : 29. marts 2010 1532
My internet is running fine and I can see the wireless router on my Wii - I just can't connect to it from either. I need access to the router menu to enable access for my Wii.
Hope you guys can help - thank
ntroller
192.168.1.9
More about : connect desktop wireless router ethernet cable
Since I can't edit:
Hmm, so my internet is NOT working when connected through the wireless router. I might have been wrong when i wrote it, or something has changed.
All symbols on both the modem and router are blinking, and when I connect my desktop to the router via ethernet it registers as being connected(ie. windows no longer tells me the ethernet cable is not connected), but I cant go online.
If I change my wireless router with some old 5 port switch hub, my internet works fine.
I suspect you have a combo DSL modem+router, and are attempting to connect the Airlink router to that, and that’s causing the problem. If so, you need to place the DSL modem+router in “bridge” mode. Then it will work.
[dsl modem+router (bridge mode)]<-- wire -->[airlink router]<-- wire -->[computer]
Related ressources
- Connect desktop to wireless router via ethernet cable - Forum
- DSL Modem/ Router only works when connected to desktop via ethernet - Forum
- Wireless Arris modem won't connect via Ethernet - Forum
- Connecting an ethernet cable to wireless router - Forum
- Can't connect via wired ethernet . Wireless if fine. - Forum
you might be right - I honestly am not sure. The modem had a previous owner, and it basically just came with the house
When I look at my connections in windows this is what I get: http://img204.imageshack.us/img204/9907/connectionsd.jp...
You mean I have to select these two connections and bridge them together?
Note; these two connections are how my internet has always been, the second one didn't come when I plugged in the router.
And thanks for your help - I really appreciate it!
No, I'm not referring to your wireless network adapter AT ALL. I'm talking about your modem. I'm assuming it's DSL, and not just a DSL modem, but perhaps also a router, a combination modem+router.
Just tell me the make and model of the modem and I can look it up and confirm it one way or another.
And what ever you did to your PC in terms of bridging those connections, undo it.
Stumbled across this on my ISPs website: http://intranet.ka-net.dk/download/blanketter/velkommen...
Document is in danish, but it might make a little sense still.
The website also tells me that LAN IP area must start 192.168.99.1, DHCP start address: 192.168.99.20, DHCP finish address: 192.168.99.40
But this might not be important at all
Ok, I can see this is NOT DSL, but a cable modem. Then you should be connected as follows:
[modem](lan)<-- wire -->(wan)[router](lan)<-- wire -->(lan)[pc]
Your PC should also be configured w/ DHCP enabled. Go to Start->Run, type "ncpa.cpl" (no quotes), and hit enter. Locate your network connection, right click it, select Properties, and you'll see the details for that connection. In the list box, locate TCP/IP, select it, and hit the Properties button. Make sure "Obtain an IP address automatically" and "Obtain DNS server address automatically" are selected. Hit OK (to close the dialog box), hit OK (to close the connection properties), and the network will reset.
Ok so, I've connected all my stuff the way you described and my internet is working this way. I did as you described and made sure all the settings were as you said.
I'm still having troubles with 192.168.0.1 tho - it's not working now. Just 5 minutes ago I had it working with the cable going from router WAN port to pc LAN port. Then I changed them again to get online, and then it won't work again.
Getting closer tho!
Getting closer tho!
There are no circumstances in which you would ever connect the PC to the WAN port of the router. Even if the WAN port of the router was not connected to the LAN port of the modem, you would STILL use the LAN port of the router and connect it to the LAN port of the PC to contact and manage the router.
Step #1) Generate an ipconfig dump when the PC is connected directly to the modem and post it here.
Step #2) Generate an ipconfig dump when the PC is connected to the router via a LAN port, and the router is connect to the modem, WAN to LAN, respectively, and post it here as well. Also, post a screenshot of the WAN IP page of your router so we can see if the router is being assigned the same information as your PC from step #1 (it should be).
To generate an ipconfig dump, go to Start->Run, type "cmd" (no quotes), and hit enter. In the command window, type "ipconfig > temp.txt" (no quotes). The file temp.txt (in this example) will contain the dump.
1)
IP-adresse for automatisk konfiguration. . . : 169.254.80.10
Undernetmaske. . . . . . . . . . . . . . . . : 255.255.0.0
2)
No resets between these, I just switched the cables around.
All through this I get the "limited connection" warning. The pc->lan->router<-wan/lan<-modem setup worked earlier tho - I just couldnt reach the router via 192.168.0.1. Then it just stopped working.
WAN IP page - not sure if it's the right one:
http://img519.imageshack.us/img519/8682/details.jpg
Anything else, just let me know!
2)
None of this makes any sense. You told me when the PC is connected directly to the modem, everything works. Yet, the first ipconfig dumps show an IP address of 169.254.80.10. That's the IP address Windows assigns when it can't reach reach a DHCP server. That’s a useless IP assignment and why Windows reports “limited connectivity”. At the very least it should show the public IP assigned by the cable modem, a valid gateway IP, DNS servers, etc.
Forget the router for the time being. Connect the PC directly to the modem (reboot the modem as well), and get a working Internet connection.
[modem]<-- wire -->[pc]
Then generate an ipconfig dump and post it here. We’re never going to make progress if you can’t get that working reliably and predictably. Also, make sure the PC is using DHCP.
I must have posted something wrong - the connection works reliably with the modem connected directly to the pc.
Sorry
Sorry
agerkvist said:
I must have posted something wrong - the connection works reliably with the modem connected directly to the pc.Windows IP-konfiguration
Sorry
OP, you're making this so difficult. I asked you to generate this very dump, then you post the previous dumps which don't look like this, now you finally do.
So are we clear now. THIS dump represents when you're connected directly from the PC to the modem, correct? NO router.
I want you to generate this same dump one more time, but this time using ipconfig /all (all future dumps I request should include the /all option as well).
This is me connected directly to the modem yes, no router.
I realize I posted the wrong dump, my mistake, so sorry
ipconfig/all>temp.txt:
Beskrivelse. . . . . . . . . . . . . . . . . : NVIDIA nForce Networking Controller
192.168.1.9
Rettigheden opnået . . . . . . . . . . . . . : 28. marts 2010 00:31:55
Rettigheden udløber. . . . . . . . . . . . . : 30. marts 2010 23:12:56
192.168.1.9
Ok, so now we know what a good Internet connection to your cable ISP looks like.
Now do the following.
1) Do a factory reset on the router. Find the reset button on the back of the router and depress it for 30 seconds (while powered on, of course) and release.
2) Reboot the modem (pull the power cord for 30 seconds and plug back in). Connect the modem to the WAN port of the router. Connect the PC to a LAN port on the router.
3) Generate an ipconfig /all dump on the PC and post it here.
Takes about 15 seconds after connecting the PC to the LAN port, then I get the limited connection warning. DHCP is activated.
And then I have to go modem->wire<-pc to post this
Very strange. It's almost as if the DHCP server on your router is disabled. Something I've never seen before as a default. Then again, I've never dealt w/ this router before.
I want you to manually configure your TCP/IP configuration as follows:
IP Address: 192.168.0.100
Subnet Mask: 255.255.255.0
Default Gateway 192.168.0.1
DNS Server: 192.168.0.1
Now see if you can get connected to the router's administrative interface at http://192.168.0.1 (username = admin, password = 1234).
http://www.tomshardware.com/forum/25949-42-change-addre...
agerkvist said:
This while having the modem in the WAN port and the PC connected to the router via LAN?Correct, from this point forward, I want you to keep the modem connected to the WAN port of the router, and PC connected to a LAN port on the router. I realize that's problematic for posting here, but there's nothing I can do about that for the time being. You'll just have to jump back and forth until this is fixed.
Try...
IP Address: 192.168.1.100
Default Gateway 192.168.1.1
DNS Server: 192.168.1.1
http://192.168.1.1
http://192.168.1.1
Same result.
At first I get the "limited connection" warning, then I change the settings and it disappears, but I get a timeout error when i try the 192.168.1.1 - I managed to connect to www.google.com. took a little while to open.
couldnt post here tho.
Disconnect the modem from the WAN port.
Reboot the router.
Try...
http://192.168.0.1
If that doesn't work, try..
http://192.168.1.1
Reboot the router.
Try...
http://192.168.0.1
http://192.168.1.1
None of this makes sense. Every router I’ve ever seen (and I’ve seen plenty) defaults to using DHCP for the local network. When you connect a PC to that router, your PC (also configured to use DHCP) will obtain an IP address from the router. That IP address is typically in the 192.168.1.x or 192.168.0.x network. An ipconfig dump should show that IP address and a default gateway IP address, typically 192.168.1.1 or 192.168.0.1, respectively, which is the IP address of the router.
But in your case, DHCP requests always fail. That’s why an ipconfig dump always shows one of those 169.254.x.x. IP addresses. That means your PC could not contact a DHCP server and had to assign itself an IP address. But that 169.254.x.x address is useless, it provides no connectivity.
So something else is amiss here. Either the LAN port is bad, the cable is bad, or the router is bad. We even reset the router back to factory defaults and it didn’t help. But it *has* to work if you do nothing more than connect the PC to the router. Forget whether it’s connected to the modem over the WAN port. That’s irrelevant at the moment. You should ALWAYS be able to take a router, patch a network cable to it over the LAN port, get an IP address from that router over DHCP, and gain access to its administrative interface. If you can’t, then as I said, something else is going on, perhaps in the hardware itself (bad LAN port, bad cable, etc.).
Is this a brand new router? Have you ever had it working before?
There has been progress. I decided to try and reset the router once more and do the modem->lan/wan<-router->land<-pc setup - then I get a webpage from my ISP saying I had to click to configure my new equipment. I did and just restarted and I can go online now.
when I opened the old 192.168.0.1 tab in firefox it asked me to log in - i chose cancel, since now it worked. Now I can't open it again tho. but im online with the wan/modem going on.
And the router is new yeah.
did a ipconfig/all just now:
IP-adresse . . . . . . . . . . . . . . . . . : 192.168.0.100
Undernetmaske. . . . . . . . . . . . . . . . : 255.255.255.0
Standardgateway. . . . . . . . . . . . . . . : 192.168.0.1
DHCP-server. . . . . . . . . . . . . . . . . : 192.168.0.1
DNS-servere. . . . . . . . . . . . . . . . . : 192.168.0.1
Rettigheden opnået . . . . . . . . . . . . . : 28. marts 2010 04:13:25
Rettigheden udløber. . . . . . . . . . . . . : 30. marts 2010 04:13:25
Might be so - but I can live with using IE for this. I'm just glad it's working...and puzzled it didn't the first time I tried the setup. Perhaps the router wasn't reset properly.
Anyway, time for bed - its 4 am at my place.
Again, thanks alot!
Next I got this geforce 8800 gts that's giving me trouble....hahaha!
See you around - I appreciate it
Again, thanks alot!
Related ressources:
- Forumhttp://www.tomshardware.com/forum/ [...] ss-windows
- ForumConnecting multiple routers via ethernet cable for range?
- ForumConnect desktop to wireless router via 3g dongle
- ForumSpeed problem of wifi router which connected to my pc via ethernet
- ForumXBOX 360 won\'t connect to internet Via Ethernet cable
- ForumCan connect to router with ethernet cable but not wirelessly
- ForumExtend wireless by adding extra router via ethernet wall port
- ForumNo internet through router via ethernet
- ForumConnecting modemwith cat5 cable to wireless router
- ForumConnect a linksys router to my desktop for wireless ?
- ForumNo connection via Ethernet Cable
- ForumAdd ethernet router to wireless network
- ForumVerizon Modem into Router
- More resources
Read discussions in other Wireless Networking categories
