Solved
Need a 120mm Cpu Cooler
Ok. So I have a NZXT Phantom, which has 180mm maximum height for a CPU cooler. I am installing the 30mm thick side fan, so that reduces it to 150mm. However, I don't want the CPU cooler like touching the fan, so I prefer >120mm. I have an i5 3550, and even though stock heatsink should be enough, its far too loud at idle for some reason, and is even louder than my GPU.
So really, I just want something that is lower than 120mm, performs even identical to a stock fan, (As long as it doesn't make it hotter than a stock fan), I just want something quiet and small. I'd also rather keep it into the $60 range.
Note: I also have a 1155 pin motherboard, so please help me.
Much appreciated
JJ1217
6 answers Last reply Best Answer
More about need 120mm cooler
  1. Best answer
    COOLER MASTER GeminII M4 RR-GMM4-16PK-R2 120mm Slim Fan Long Life Sleeve Bearing CPU Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103177#top
  2. Oh ok sweet, is this quiet and at least on par with the stock heatsink?
    Thanks.
    Thanks.
    Yes ;)
  4. If I wanted it even quieter, should I just stick a Noctua fan on it? I really hate noise, especially when it comes through my sound cancelling headphones.
  5. Yes it would be even quieter then
  6. Best answer selected by JJ1217.
Heatsinks Cooling Fan CPUs Overclocking Product
