Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > System bus speed will downgrade................???
Forum CPU & Components : CPUs System bus speed will downgrade................???
should i install am2+ or am3 cpu on am2 motherboard????
i have no other choice bcoz i recently bought a new motherboard which is unfortunately am2!!!
Reply to laeeq1753
The disclaimers on motherboard's indicate that the HT link speed would downgrade to HT1.0 speeds. The good thing is that HT link speed does not impact the performance of the processor. As HT is used by peripherals and is separate from the link between ram-processor.
If short, buy whichever suits your budget and whichever is faster.
Reply to amnotanoobie
Actually the answer is to buy what your motherboard will support. It won't handle AM3, thats 90% certain. It might handle an AM2+, but check the manufacturers website to make sure. You'll probably need to upgrade the bios as well. (and you'll need a CPU in there to do that.)
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
There are 1860 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Heat-sink recommendation for i5-2500k LGA 1155 CPU
By lilotimz, 6 hours ago:
The best performing and efficient CPU cooler under $50 would by the CM Hyper 212+ or CM...
Best offers
Top experts
