Ghythybhy Distinguished Oct 29, 2011 194 0 18,680 Sep 17, 2012 #1 Where can i buy those rubbers? I want to mount another fan on my CPU cooler and i don't know where to buy this freaking RUBBER THING. I need your help! I want to mount another fan on my CPU cooler i just don't have those Rubber Mounts
inzone Champion Mar 12, 2011 14,971 1 51,960 Sep 17, 2012 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16811996019 You probably don't want to spend this much but this is what I found for now. Upvote 0 Downvote
inzone Champion Mar 12, 2011 14,971 1 51,960 Sep 17, 2012 #3 http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=60_325&zenid=df65326536daeb8f44e95e58ed27351d This is probably more like what your looking for and the price is much better. Upvote 0 Downvote
Ghythybhy Distinguished Oct 29, 2011 194 0 18,680 Sep 17, 2012 #4 I'm not sure if it will fit on my CPU Cooler Xion-HP1216b My CPU COOLER is the exact same thing on the picture. Upvote 0 Downvote
inzone Champion Mar 12, 2011 14,971 1 51,960 Sep 17, 2012 #5 When you buy a fan they usually come with the fan unless your trying to use a fan that you have already and don't have the rubber screws. None of those that I linked in the second post will work? This one loofs like what you now have. http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=60_325&products_id=3294 Upvote 0 Downvote
