Hi, guys!
I recently bought two 14 cm fans for my new Xigmatek Midgard case. I planned to install one on the side for intake and one on top for blowing air out. But I cannot take the top cover off! I cannot find any screws, I cannot move it even slightly when I pull or push - nothing. Can someone explain to me how I can install a cooler on top of the case? I cannot find any other info elsewhere.
Also, I noticed the airflow from the front intake cooler was extremely weak - I couldn't even feel it at the top speed inside the case. There are hard drive bays right in front of the cooler, so very little air comes through, but creates a lot of noise. I don't see any point of having it there (well apart from the cool lights). It does cool my hard drive a bit, but its temperatures are only 38 C degrees so far and I doubt it will overheat. So removed it (probably I will place it on top or on the side). Is there anything else I should be aware of?
