Intel i5-750 Gigabyte ga-h55m s2hp, F3 and F4 (latest BIOS)
XFX GTS 250 1GB
XFX 750W PSU
4GB of GEIL (2x2GB DIMMs) - rated DDR3 1333 1.5v
Tested with value Kingston and Coursair and the problem persist
I bought a motherboard ga-h55m-s2hp and unfortunately she is not using the full 4 Gb system perfectly in a 64-bit only 3.8 GB
Memtest does not accuse errors
I'm using the i5 750 and a video card offboard and the bios continues reserving memory even with video offboard.
In the bios detecting 4Gb is made, but upon entering the system 64-bit operating it incorrectly reserve memory.
The problem I have occurs in other motherboards from gigabyte with other users
http://forums.tweaktown.com/gigabyte/39790-possible-use-full-4gb-ga-h55m-ud2h.html
http://forums.overclockers.co.uk/showthread.php?t=18102404
http://forum.giga-byte.co.uk/index.php/topic,2535.0.html
This decreased my performance since it does not i use the full 4 Gb of dual channel only 3.8
Test all the hardware with other ga-h55m-s2hp and the problems persisted
Test all the hardware with another motherboard (ASUS) and no problems and pins are no problem, which demonstrates that there is a defect manufacture this motherboard or bios.
This can not be normal. This is a failure.
Possibly a flaw that was not observed in tests and can be fixed by a bios update.
Note well the "Activates the onboard graphics only if no PCI Express graphics card is installed"
And still reserving memory for activation, the problem is here.
My processor is an i5 750 and it has no VGA on it.
So my question is:
It is normal for H55 chipset you have memory allocation to force even if you use a VGA offboard and do not use the onboard VGA and disable the onboard VGA in the bios or is it a fault of the manufacturer? (Gigabyte)
You guys that have a motherboard chipset with H55 can use the full 4 Gb?
Sorry for bad English.
XFX GTS 250 1GB
XFX 750W PSU
So my question is:
