Motherboard help
Hello Toms Hardware. I have just registered and I am building a gaming PC.
I really need to find a motherboard. Here's what I need it to support/have:
LGA 1366 Socket (i7)
3 PCI Express 2.0 (Supports 3-way SLI, 16x16x8)
Any size, i would prefer just keeping at Regular ATX, and not extended. But If you find an amazing one that is extended that is ok.
I'd like to keep the price around $200-$250. Lower if it could be.
Thank you.
6 answers Last reply
More about motherboard help
  1. Hello and welcome to the forums
    X58A-UD3R is good a choice,ASUS RAMPAGE III Extreme is also great
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131642
    However its out of your price range and that's because you need a motherboard with x16x16x8 SLI support, you can however go with motherboards that support SLI with x16x8x8 which will give you roughly the same performance(maybe 5% slower on very high resolutions like 2560x1600 or higher), and save some cash.
    In that case,ASUS P6X58D-E is a good choice and fits in your price range
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
  2. Wow guys. Thank you for replying.
    So, heres what I am wondering.
    Say I have 4 GTX 470's and a ASUS Rampage ||| Extreme.
    Would have 3 if them in 16x8x8 be better than 4 of them 8x8x8x8?
    The one with all 4 cards correct? The reason I'm asking is because I really don't know the difference it makes with 16x and all.
    I think I might save a little more andd get then Rampage though.
  3. Well 3-way and 4-way SLI aren't very optimized,so don't expect a huge difference between 2-way SLI compared to 3-way and 4-way SLI.
    However since you already have 4 cards,then the only possible(and the best) configuration is 8x8x8x8x
    If you had 4 gpu's bank on shopping for a new case like a HAF X otherwise they won't fit.
  5. I just plan on having 3 GTX 470's in the end.
    It's supposed to fit, I will have the Antec 1200, a Full-ATX case.
Motherboards Product
