I've decided to retire my first built PC. I got 7 years out of it so I feel I got my moneys worth. Below is the build I'm going for but looking for any educated suggestions. I plan to order tomorrow in hopes to build on Sat. Thanks in advance!
*I intend to use for gaming but Im not hardcore so no overclocking. I dont want to have to worry about checking the specs on the back of a box when I buy a game though.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811156098
Media: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148335
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Proc: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130236
Proc/MB are a bundle from newegg @ $289
GPU: ATI Radeon HD 4670 (It's a freebie!)
My concerns are the motherboard and memory. I dont need the onboard video card so Im curious if that will cause any problems with adding my 4670. Any suggestions for another card would be appreciated to possibly save money. I wasnt able to confirm compatibility with the memory/MB sooo..
1) Any need for me to change the MB
2) If so, what suggestions
3) If not, will the memory I have selected work?
4) If not what memory based on your suggested MB?
Sorry for the long post but I appreciate any support!
