Hello,
Had a hard drive crash last week. Maxtor Diamond Max 9 200g (2004). It played the song of death. The drive wasn't spinning. Tried several hours and still wouldn't work. Got 20yrs experience and have used the freezer trick before. Put the drive in a ziploc baggie and in the freezer for 1hr. Plugged it in my external case and it sounded different. Sounded like it wanted to spin. Only played the song a couple times. Turned it on and off a couple times then it started to spin up. Unhooked the usb cable and reconnected it and all the partitions showed up and I immediatly copied all the partitions to another external which took 8 hrs. I did have backups but not up to the day.
Reason I'm posting this is I read on some data recovery sites the freezer method is a myth, old wives tale and they discounted it saying they've never had a drive recovered by putting it in the freezer. Well, I just had it work (again). Put it this way, what do you have to loose?
P.S. I had 2 drive problems so if anyone reads my other posts that would clear any confusion.
