Hey everyone!! I just got my build finalized with everything but cooling. I want to do watercooling as i like the idea of the more quiet setup as well as the ability to keep temps low. On top of that it just looks cool.
My problem that im having is im sort of confused. I have read through the sticky and have checked out skinnelabs and several other websites and forums. However im still completely lost. I have the understanding of how the watercooling system works and how to put it together (i have done this 2 times before). I have not however ever picked the parts and brands. Every forum i go to its bashing of one brand or another or constant arguments on why this or that is better. I have also looked at charts myself and most of the time the things that im seeing are within 1-2c apart.
Basically what i want to know if you wouldnt mind is what setup i would need to have to cool a 3770k and 2 7970s. I have read and seen setups that have 2 radiatiors but from what i can tell the 7970s only put out around 425-450tdp(i may be wrong) and i dont think that the 3770k puts out enough to justify 2 rads. I have the switch 810 case and i want to keep everything as internal as possible. So what rads show i go with as well as what pump and blocks. The fittings and the tubes ill find on my own. I want to try and keep it around 500-600 dollars if possible. I dont want to spend more money than is neccasary. If cant do it on this budget please let me know so i can stop daydreaming and actually be realistic!
Thanks for looking guys and i cant wait to see what you all come up with!
