hi guys i need help. im low on budget and I KNOW this system won't be a monster. it's my first try building a system and would like to gain as much experience and have fun in the process. i just need a few pointers and feedbacks on what and how i can improve my build. i plan to OC the cpu a little but as much as possible stay away from liquid cooling solutions and stick to the fans. i dunno which fans are good. im looking for something that's cheap but reliable. (not necessarily the cheapest and lowest quality fans). oh btw, fans that'll fit into the CM-335 chassis perfectly (without removing the side panel of course). i chose that chassis solely for its looks not because of its capabilities and features. i dunno, i just fell in love with it.
a run down on my build:
CPU - athlon ii x4 620 (plan to overclock it to at least 3.0GHz)
RAM - Team Elite 4gb(2gbx2) CL9 1333mhz
MoBo (unsure) - EMX-785G DDR3 or MSI 785GTM-E45 (dunno which on is good for OC'ing)
PSU - HEC 550watts (550 Power) Cougar Series 80PLUS atx psu, full range, active pf (cheap, i know right.)
case - CM 335 - i wont change this (but if you are able to convince me....)
CPU fan - i have no idea..
ODD - a basic dvdrw will do
target is to keep everything under $500.
i plan to invest more on the gpu but i opt to wait for the fermi cards.
would get an ATI 5770 any day if fermi are abysmal.
thanks!
edit:
i'll be gaming a lot and would watch 1080p movies every now and then. what other possible options from my build can you guys suggest? especially the ram and mobo where i really dont know which brand to pick. again, the idea is to keep everything under $500.
thanks!
edit:
