Today we have several different types of cooling to choose from when deciding to cool our CPU’s. Air coolers can get rather big and heavy and can make a lot of noise when running at full loads. Full blown water cooling units do have excellent performance but can cost a lot more for this extra performance plus installing these can be difficult. In the middle area we find sealed water cooling units with the double wide rad units being the best. We have seen double wide rad units for some time and have found they generally provide better cooling then air coolers and only cost a little more.
Taking the 240mm rad sealed liquid cooling units and making them better is just what Thermaltake set out to do with the WATER2.0 Extreme CPU Cooler.
Specifications for the WATER2.0 Extreme:
Water Block Material - Copper
Pump Motor speed - 2800±150 RPM
Rated Voltage - 12V
Rated Current - 220mA
Fan Dimension - 120 x 120 x 25mm
Fan Speed - 1200~2000RPM
Noise Level - 27.36dBA(Max)
Rated Voltage - 12V
Rated Current - 0.5A
Max. Air Flow - 81.32CFM
Connector - 4 Pin
Radiator Dimension - 270mm x 120mm x 38.3mm
Material - Aluminum
Cooling Surface Area - 4755cm2
Tube Length - 326mm
Material - Rubber
Weight - 1,150g
Features to note:
• Rubber hoses that allow better flexibility when installing the unit.
• Thicker high efficiency radiator.
• Powerful dual cooling fans.
• Higher performing water block and pump.
• The ability to control the unit with software.
Front and back pictures of the box.
And opening the box to see everything inside.
The mounting kit has universal socket compatibility.
Intel: LGA2011, LGA1366, LGA1156, LGA1155
AMD: FM1, AM3+, AM3, AM2+, AM2
The high performance water block and pump assembly comes with paste TIM. The actual finish of the block is very smooth.
The 240mm Radiator + pump and hoses.
PMW enabled fans.
Connectors used for this cooler are.
A USB connector, a power connector that plugs into the CPU Fan header and two PWM connectors to plug the two provided fans into.
The finial unit with fans mounted and ready to be installed on the main rig.
My test bed is my main rig which at this time is a Gigabyte Z68X-UD7-B3 & 2500K @ 4.8ghz. What better way to test cooling then with something you use every day. This is running on an open air bench table.
