Hi, I am building my first system and would appreciate any comments or pointers.
I have decided on the i5 750 but I am a little unsure on the other parts. I want a good system thats going to last, but I don't want to overspend and get something thats too high spec for my needs. Although I will be gaming, its not my main use for the computer
APPROXIMATE PURCHASE DATE: ASAP
BUDGET RANGE: £750 (= $1,200 )
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Media/films/internet, Photo editing, Gaming, Audio creation, Light video editing
PARTS NOT REQUIRED: keyboard, mouse, speakers, OS, Case, monitor
PREFERRED WEBSITE(S) FOR PARTS: Dabs.com, ebuyer.com
COUNTRY OF ORIGIN: UK
PARTS PREFERENCES: No
OVERCLOCKING: Yes, potentially. Need to research still
SLI OR CROSSFIRE: Yes (for future upgrade)
MONITOR RESOLUTION: Either 1680x1050
ADDITIONAL COMMENTS:
The P7P55D-E PRO seems a highly rated mobo on here, but will I need something this high spec? i.e. if Sata 6 USB 3 aren't essential, then what is an alternative mobo that is good but comes in a bit cheaper?
Will the ATi 5770 be sufficient for gaming? I would like to play games (mostly FPS) but this will not be the main use of the system, so I dont want to spend too much money on the GPU if I can get away with it, but if I cant play the latest games its a waste of money. Maybe further down the line I will chuck another one in using crossfire, but will 5770 be ok for now?
I want to get 4GB RAM of a good make, but other than that I'm a bit confused as to which type will go with which motherboard. Other than getting DDR3 I'm not to sure what to look for. Is 1333MHz ok or will
I need 1600?
thanks a lot!
Intel Core i5-750 Quad Core 2.66GHz 8MB Processor £152.06
http://www.dabs.com/productview.aspx?Quicklinx=656Y
Asus S1156 Intel P55 DDR3 ATX A L (SATA 6GB, USB 3.0) P7P55D-E PRO £149.85
http://www.dabs.com/productview.aspx?Quicklinx=6CXS
Samsung Spinpoint F3 1TB 7200rpm SATA 3Gb/s 32MB £63.86
http://www.dabs.com/productview.aspx?Quicklinx=65QC
Sapphire Technology ATI Radeon 5770 HD 850Mhz 1GB PCI-Express HDMI £126.21
http://www.dabs.com/productview.aspx?Quicklinx=68CH
Corsair Memory 750W TX SERIES ATX £90.31
http://www.dabs.com/productview.aspx?Quicklinx=4RYB
Corsair Memory DDR3 1333MHz 4GB kit of 2x240 pin DIMM"s, Unbuffer £94.65
http://www.dabs.com/productview.aspx?Quicklinx=6JQN
I need 1600?
thanks a lot!
