Problem while im using Symantec PartitionMagic
I've a problem while im using Symantec PartitionMagic on HirensBoot cd.
After I click F12/F8 I got a program list (everything is great now)
but when i click the PartitionMagic it only came a green screen, the little window where i should do all the changes dont came so i cant use the Partition tool,,,
I have a XFX GeForce 9500GT and
Samsung SyncMaster T220
Is there any settings on the monitor or the display card (GPU)
Please help me!
Im very sorry for my english.
7 answers Last reply
More about problem symantec partitionmagic
  1. What OS are you using?
    I don't beleive that PM was ever revised to be compatible with Vista or Win 7.
    Im using Win7 Ultimate and PartitionMAgic have worked before at my laptop so i dont understand why its not work wih my PC
  3. rockyjohn said:
    but when im using an other monitor i could use it any way,, dont know why
  4. I have no idea why something might show up on another monitor, but I certainly would not mess with hard drive partitions using software like Partition Magic whose manufacturer will not say it is compatible. I strongly recommend using compatible software.
    If you persist with PM, then I recommend you back up all your data and consider you risk being required to reformat your disk and reinstalling all you software and settings.
  5. PT Magic don't support Vista and W7.
    I switch to Acronis Disk Director for Disk Management and Acronis True Image for Disk Mirroring or disk/file backup. It works on Vista & W7.
    Link ? : )
Nvidia Symantec Graphics
