HI
First post and need help.
Got a new PC and want to connect
LCD TV via optical out on tv as speakers are rubbish (take it via PC into AV30s).
M-Audio AV30s but nearly all or all cards can do this also-
Connect to my AV amp via coaxial or optical.
And hopefully have decent audio playback.
The only card I have seen with the connections I need is the Trust DX514 (SC5250) but I have never associated Trust with quality really, probably my bad. But seeing as the main connections are optical, quality should not really matter, is that correct?
If I could get the connections I need on a fairly cheap Asus I would be very happy but I don't know if there is one.
So I need a card with mainly optical In and prefer Coaxial Out or Optical Out.
Will the Trust card be OK or can anyone recommend another.
Thanks in advance.
Thanks in advance.
