Noise CPU Sound on loading
G
Guest
Guest
Hi all,
I recently bought a new computer and i had a problem with the CPU or board i dont know im not sure
When my computer is idle there is no sound but when i make a scroll to a page or highlighting icons it start to make a noise
and i have monitored my CPU status through CoreTemp32 the sound is come exactly when going on higher voltage i mean
when the CPU is in idle status there is no sound and the core speed is 1600 Mhz and voltage is 43 watt once the Speed goes
up to 2.8 Ghz (the stock speed) I7 920 Bloomfield processor and the motherboard is Gigabyte X58A-UD3R....
The voltage raises up to 140 Watt there the sound appears
and it can be heard easily the sound is like a friction of two pieces into each other i mean its like electric sound like if a cable had
a shortage power but i checked everything is ok and there is no shortage so i am really disappointed on whats going on
is there any help i can get here please help me out to solve this issue???
G
Guest
Guest
@shaun o thank you sir for your advice yeah i was think so as that maybe its an issue on board, However i took the case to the one i bought the board from and he said i will see if the board has a problem i ll replace it,
@popatim no its not a cpu issue as the cpu is not very over loaded the sound appears exactly when raising up from idle to load status.
