Any Cooling Blocks?
  • Water Cooling
  • Cooling
  • Overclocking
September 22, 2012 7:12:51 AM
I've been looking for a 660ti cooling block for the past 3 hours and can't seem to find one, it seems like they haven't even been invented yet. Are there any out on the market yet?
Thanks in advance,
Jacob.
More about : cooling blocks
a b K Overclocking
September 22, 2012 7:18:48 AM
Apparently the PCB design is the same as the 670, so 670 blocks are compatible. Head over to www.coolingconfigurator.com and try putting in your GPU to see what I mean. If it shows up as reference design than any 670 block should work.
Hope this helps
m
l
a c 190 K Overclocking
September 22, 2012 7:25:34 AM
And you can always use universal blocks with heatsinks for Vram
Moto
m
l
September 22, 2012 7:32:17 AM
Does that mean I can mix my copper fittings with Nickel+Acetate?
Also I have a G1. Assassin 2 if that changes anything.
m
l
September 22, 2012 2:30:58 PM
I have some nickel fittings and all copper blocks with no problems, the only nickel I'd say to avoid is EK Nickel,
Moto
m
l
