I have a desktop that if any usb touches the usb port the whole system shuts down instantly. The system will turn back on but with no picture. I then have to turn the power supply off at the switch, wait a couple seconds, turn the power supply back on, and then turn the machine on. It will run fine until a usb tries to enter that port again. Is it a short? It is a front panel usb port.
The system worked fine for months and now this. I also have an identical system that when it is off for more than two days will get a BSOD on boot. However, if I turn off the power supply at the switch and then turn it back on after waiting a couple seconds it will be fine. The system will reboot fine and if off or a weekend will be fine.
Both systems are identical barebone kits from Tigerdirect.
