Amd PII 920 heat problems??
I have an AMD Phenom II x4 920 processor and Gigabyte GA-MA785GM-US2H mobo.
When i run the stability tests in AMD Overdrive, it shows temp upto 62-65* C.
Is this normal??
I use the stock cooler which i recieved with my pro. Should i change the cooler?? or is this the problem of my case?
2 answers Last reply
More about heat problems
  1. I think that's about right. A little toasty, but nothing to worry too much about.
  2. Thanks. I was a little bit too worried about these values.
CPUs Cooling AMD
