Wow, those are a lot of terrible choices mfarrukh
The WC kits you list are of exceptionally low quality and that 'HDD Cooler' is actually made to cool Corsair Dominator RAM.
The only good parts you list would be the Swiftech radiator and pump.
OP, are you looking to WC just the i7 or the GPU's along with it?
If you only are looking to cool the CPU and are on a budget, you can locate a great
Swiftech Kit Here.
If you are looking to cool both GPU's and the CPU, I would recommend at least 2 360mm radiators, a pair of MCW60's, a Apogee XT and a Laing D5 or MCP655 pump.
