Sign-in / Sign-up
[HELP] EPS12V and EATX12V Insecurity
  • Power Supplies
  • Motherboards
  • Components
Last response: in Components
April 3, 2010 11:37:30 AM
Hi everyone,
I just got all my components in and started building the system and got stuck at the PSU installation. The PSU I bought is the:
Antec TruePower 750W Modular
And my motherboard is:
Asus P7P55D-E Pro
Now my PSU has the following connectors on the 12v rail:
20+4 Motherboard
4-pin ATX12V
8-pin EPS12V
and then all the Molex and SATA and PCI-E rails and modulars.
My Motherboard needs the EATXPWR 24-pin (Check)
And then the EATX12V 8-pin (unsure) is the EPS12v another name for EATX12V? And are they compatible or should I be using the 4-pin ATX12v?
Thank you for you help
More about : eps12v eatx12v insecurity
a c 244 ) Power supply
a b V Motherboard
April 3, 2010 11:50:42 AM
Yes
April 3, 2010 11:51:54 AM
Fewf so I just plug the 8-Pin EPS12V and everything will be A-OK?
a b V Motherboard
April 3, 2010 11:54:56 AM
It's the proper connector, can't say for sure that everything will be A-OK, there's too many variables.
April 3, 2010 12:17:45 PM
well thats all I needed to know at least for this problem thanks a lot for you expertise
