Hey all , I'm running Windows 7 Ultimate 32 bit with 2 gb ram , amd athlon II 240 @ 3.6 and asus 4770.My problem is that Smart Doctor is not remembering clock settings correctly after reboot.I'm using riva tuner to overclock the memory and core and smart doctor for the voltage.
On Windows XP usually when I reboot/start the PC riva tuner will apply the clock settings and smart doctor the voltage settings.But now on Win 7 riva tuner will apply the clock tweak and smart doctor will UNDERVOLT my GPU to 0.9v(0.95 is default),instead of applying 1.04v(the settings I inputed).
Firstly I thought the two programs are conflicting with each other , so I disabled Riva Tuner "apply at start up" clock and used smart doctor to just tweak the voltage and set it to remember , but alas after the reboot it was again at 0.9.If I set it to not remember my clock settings it starts normally at 0.95v.Another thing I noticed is that Riva is applying the settings first , then smart doctor
So anyone knows a solution to this ?I just want it like when it was on XP - at boot up SD and Riva apply the settings and its a done deal.Thanks for reading.
ps I'm not sure if this is the correct category , so if its not please move it to the correct one.
