Hi all,
I am trying to figure out the most cost efficient way to get video/audio from my PC setup to my HDTV.
I do not wish to change my GTX 260 graphics card nor my Gigabyte 965P-DS3P (Rev3.3) motherboard or any of my components for that matter due to budget.
My understanding so far is that i should be able to send audio/video through the following configuration:
Motherboard SPDIF out(internal)>GTX260spdif input>DIV/HDMI adapter>HDMIcable>HDTVinput
is this right?
If so, i believe my problem is that i do not have a SPDIF out (internal) pin connection present on my motherboard.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2455&ProductName=GA-965P-DS3P
In the past i have tried using the various I/O panel audio connections on the motherboard to take sound to seperate speakers/HDTV audio inputs - always without success. It's possible the audio connections are broken in someway or that my HDTV audio inputs are somehow just not compatable. I have only ever been able to get sound from the 6x audio jacks from the I/O panel through my X-Tatic 5.1 sourround sound headphones.
Am i right in thinking that the solution would be to purchase a sound card with an internal SPDIF pin out? new configuration:
Motherboard>Soundcard SPDIF out(internal)>GTX260spdif input>DIV/HDMI adapter>HDMIcable>HDTVinput
If so, can anyone recommend such a card?
Thanks for your time
Colin
Glasgow
is this right?
Colin
Glasgow
