Motherboard - Asus P5Q Deluxe
CPU - Q9550 2.8Ghz overclocked to 3.4Ghz (safely never goes higher than 50 degrees even with a heavy load)
Case - Antec 900
Storage - Western digital 500gb S-ATA II
RAM - Corsair XMS2 DDR 2 800MHZ running at 4-4-4-12 (heat sinq edition)
Graphics card - Sapphire 4870
Internet connection - 20Mb
This is a general problem which has happened since i upgraded my CPU and Motherboard. THis problem did not happen straight away either. I installed windows XP media centre and windows 7 before the issue arised.
The general problem seems to be with installing operating systems. I decided to delete windows 7 64-bit edition due to a couple of issues i had with the operating system. so i decided to go back to windows vista and i was suddenly getting issues with the installation. It wasnt enough for the installation to crash but it was installing dramatically slower (would be on 0% for around 25 minutes then go up to 35% when expanding files) The installation would return to normal speed after this and be finished within minites.
The true problem is when it comes to updating the OS using Windows update. The download would take forever to initialise and when it did it would be terribley slow (didnt see this as an issue because it could obviously be the speed of the windows server or my connection being throttled) so i ignored this issue. The problem came when it came to installing the updates. I was installing around 360MB of updates and it took over 2 and a half hours with it stuck at 50%. This has never happened even before with my slower system. I have tried using different Operating systems thinking it could be the version but it happens every time. I also noticed my drivers took a long time to install (around half an hour to install 4 drivers).
Am i worried for no reason or is this a genuine problem because i expected a speed increase not everything taking longer
Anymore information please ask as i could understand this explanation being vague to someone else
Any suggestions will be much appreciated. Thank you
Case - Antec 900
