Hi Guys,
I have a Phenom 965 BE with a ASRock 970 Extreme 3 motherboard
I have recently been trying overclocking, managed to set my multiplier to x19 getting it to 3.8Ghz and the voltage to 1.4v
It works perfectly, infact it runs cooler than the stock clocks but my problem is :
When i open CPU-Z it shows that my cpu is at 3.8Ghz but every 20 seconds or so the clocks will drop down to 3Ghz or sometimes 3.2Ghz for a split second and then jump back up. This is usually much more frequent at maximum load
Here are some pics
http://i46.tinypic.com/291nzmo.jpg
http://i50.tinypic.com/10fdstf.jpg
Thanks in advance
Here are some pics
Thanks in advance
