Retstart problem
Last response: in Systems
Homebuilt system Authority
Perhaps you could be more specific...
I presume you're referring to your reset button, as you mentioned switch. If this is indeed what you're referring to, then chances are it is the switch. Seeing as how this is a prefabricated system, i'm also presuming that the on board audio chipset power wire and reset switch wire are all connected to one big connector. If so, then you may have a short in the connector.
Ask the community
